Inleiding
This guide will show you how to remove your HP Pavilion 15-eg0025nr battery. The battery is located on the underside of the laptop and powers the laptop when it is not being charged with a power cord.
Your HP Pavilion 15-eg0025nr battery may need to be removed if it is broken and needs to be replaced. If your laptop dies frequently when it is not being charged, it may be a problem with the battery. To find out if your HP Pavilion 15-eg0025nr battery needs to be replaced, visit our troubleshooting guide. Other repairs to the laptop may also require that you remove the battery beforehand.
Wat je nodig hebt
Flip over the computer so that the back panel is facing upwards.
Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
