Ga door naar hoofdinhoud
HP Pavilion 15-d017cl Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 15-d017cl Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 HP Pavilion 15-d017cl Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Flip the laptop onto its back in order to have access to the back "L" shaped panel.
    • Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
  2. HP Pavilion 15-d017cl Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-d017cl Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
    • This may require a good amount of strength to loosen the panel. As the opening tool is moving around the panel, clicking noises will be heard.
  3. HP Pavilion 15-d017cl Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the fifteen (15) 5 mm screws using the Phillips #1 Screwdriver.
  4. HP Pavilion 15-d017cl Hard Drive Replacement: stap 4, afbeelding 1 van 3 HP Pavilion 15-d017cl Hard Drive Replacement: stap 4, afbeelding 2 van 3 HP Pavilion 15-d017cl Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Flip the computer over so the screen and keyboard are showing.
    • Using the opener tools, pry around the edges of the computer in between the keyboard and the base.
    • Apply enough pressure to unlatch the keyboard but be cautious of the parts under it.
    • Flip the keyboard up toward the screen to access the motherboard.
  5. HP Pavilion 15-d017cl Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-d017cl Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-d017cl Hard Drive Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the Spudger, press into the silver latch and lift it up.
    • Using the Tweezers, pull the Ribbon Cable out of the silver latch.
  6. HP Pavilion 15-d017cl Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 15-d017cl Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 15-d017cl Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove the three screws located around the hard drive.
    • When finished unscrewing, pull the hard drive out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 1,175
