Ga door naar hoofdinhoud
HP Pavilion 15-cs3xxx Battery Replacement
Wat je nodig hebt
  1. HP Pavilion 15-cs3xxx Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 15-cs3xxx Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power off and unplug the laptop from any power source.
    • Flip the laptop over so the bottom is facing up.
    • Prior to removing the two screws near the hinge, remove the two rubber feet with a spudger or opening tool.
    • Two of the five screws are under the rubber feet nearest the hinges.
    • Use a Phillips screwdriver to remove the five screws on the underside of the laptop.
  2. HP Pavilion 15-cs3xxx Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-cs3xxx Battery Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool and picks to carefully pry off the back cover.
    • Work your way around the perimeter and release the clips holding the case to the device.
    • Carefully remove the back case.
  3. HP Pavilion 15-cs3xxx Battery Replacement: stap 3, afbeelding 1 van 1
    • Locate the battery which should be a large rectangular component located at the corner of the laptop.
    • Use a screwdriver to remove the four screws holding the battery in place.
  4. HP Pavilion 15-cs3xxx Battery Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the battery from the chassis.
    • Install the new battery and repeat the process to secure it.
Conclusie
Following these steps in reverse order to reassemble your device
4 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 175
Altijd: 3,278
