Ga door naar hoofdinhoud
HP Pavilion 15-cd040wm Back Cover Disassembly
Wat je nodig hebt
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: stap 1, afbeelding 1 van 2 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: stap 1, afbeelding 2 van 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: stap 2, afbeelding 1 van 2 HP Pavilion 15-cd040wm Back Cover Disassembly: stap 2, afbeelding 2 van 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: stap 3, afbeelding 1 van 3 HP Pavilion 15-cd040wm Back Cover Disassembly: stap 3, afbeelding 2 van 3 HP Pavilion 15-cd040wm Back Cover Disassembly: stap 3, afbeelding 3 van 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Joe Krawczyk
397 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G1, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G1
4 Leden
7 handleidingen geschreven
3 opmerkingen
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - Antwoord
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - Antwoord
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 141
Altijd: 8,283
