Inleiding
If your computer will not turn on and you know that this is due to a defective hard drive, this guide will take you through the steps of removing it on the HP-Pavilion 15-cc023cl.
Wat je nodig hebt
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
Use a spudger to lift the latch that holds the hard drive cable in place.
4 andere personen hebben deze handleiding voltooid.
