Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Make sure the power cord is not plugged in and that the device is powered completely off before you begin. Before making any hardware changes to this laptop, make sure the battery is completely removed. This will make repair safer for both you and your laptop.
Onderdelen
Geen onderdelen opgegeven.
  1. Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel. Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery. Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  5. Disconnect the port connecting the battery and the motherboard and then remove. Disconnect the port connecting the battery and the motherboard and then remove.
    • Disconnect the port connecting the battery and the motherboard and then remove.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Één commentaar
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 64
Altijd: 1,651
