Ga door naar hoofdinhoud
HP Pavilion 15-ca2073cl Battery Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ca2073cl Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-ca2073cl Battery Replacement: stap 2, afbeelding 2 van 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Battery Replacement, Battery: stap 3, afbeelding 1 van 2 HP Pavilion 15-ca2073cl Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 2,001
