Inleiding
This guide will assist you to replace the touchscreen for HP Pavilion 15-bk020wm there are prerequisite guide to get to the touchscreen. Be sure to disconnect your device from the power source and ensure it is powered down.
Wat je nodig hebt
Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
Remove the two screw cover strips.
Remove the two screw cover plugs.
Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
Detach the blue ZIF cable from the bottom of the laptop.
Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
Één andere persoon heeft deze handleiding voltooid.
