Ga door naar hoofdinhoud
HP Pavilion 15-ba003ds RAM Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ba003ds RAM Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 15-ba003ds RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: stap 2, afbeelding 1 van 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds RAM Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 15-ba003ds RAM Replacement: stap 3, afbeelding 2 van 2
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds RAM Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 15-ba003ds RAM Replacement: stap 4, afbeelding 2 van 2
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds RAM Replacement, Backplate: stap 5, afbeelding 1 van 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: stap 5, afbeelding 2 van 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: stap 5, afbeelding 3 van 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: stap 6, afbeelding 1 van 2 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: stap 6, afbeelding 2 van 2
    • To release the RAM, hold and pull the strips outwards on either side of the RAM.
Conclusie
Krushnam Badami
342 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 341
