Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Power off the device and disconnect from any power source.
Turn the device upside down and ensure the back of the device is facing you.
Push both buttons towards one another simultaneously. The battery slightly pops out.
Use JIS #1 screwdriver to remove the eleven 6 mm screws.
Locate the two screw holes that allow access to removing the keyboard.
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
Using a plastic opening tool, release the keyboard clips.
Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
