Ga door naar hoofdinhoud
HP Pavilion 15-b109wm Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion 15-b109wm Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-b109wm Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-b109wm Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Pavilion 15-b109wm Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Pavilion 15-b109wm Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 2 HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Keyboard Replacement: stap 8, afbeelding 1 van 2 HP Pavilion 15-b109wm Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Keyboard Replacement: stap 10, afbeelding 1 van 3 HP Pavilion 15-b109wm Keyboard Replacement: stap 10, afbeelding 2 van 3 HP Pavilion 15-b109wm Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
Conclusie
David Atunlute
241 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S2-G2, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G2, Peak Fall 2018
UMASSD-PEAK-F18S2G2
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 394
