Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This replacement guide will show how to replace the fan inside of a HP Pavilion 15-b109wm. This process will take between 30-45 minutes, if done correctly. Remember to take your time and do the steps correctly since you are working near the motherboard.
Wat je nodig hebt
Using a JIS #1 screwdriver, remove the five 5mm screws.
Detach the power button cable.
Detach the touch pad cable.
