Ga door naar hoofdinhoud
HP Pavilion 15-ay041wm RAM Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ay041wm RAM Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 15-ay041wm RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-ay041wm RAM Replacement: stap 2, afbeelding 2 van 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm RAM Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-ay041wm RAM Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-ay041wm RAM Replacement: stap 3, afbeelding 3 van 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm RAM Replacement, Disc Drive: stap 4, afbeelding 1 van 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm RAM Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-ay041wm RAM Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-ay041wm RAM Replacement: stap 5, afbeelding 3 van 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm RAM Replacement, Keyboard: stap 6, afbeelding 1 van 3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: stap 6, afbeelding 2 van 3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: stap 6, afbeelding 3 van 3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavilion 15-ay041wm RAM Replacement, RAM: stap 7, afbeelding 1 van 3 HP Pavilion 15-ay041wm RAM Replacement, RAM: stap 7, afbeelding 2 van 3 HP Pavilion 15-ay041wm RAM Replacement, RAM: stap 7, afbeelding 3 van 3
    • Orient the base of the laptop with the base facing away from you.
    • With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
    • Simultaneously, use your index finger to push the RAM sticks towards you.
    • The RAM stick will release and pop up and out.
  8. HP Pavilion 15-ay041wm RAM Replacement: stap 8, afbeelding 1 van 2 HP Pavilion 15-ay041wm RAM Replacement: stap 8, afbeelding 2 van 2
    • Repeat the same process for the top RAM stick.
    • The RAM stick will release and pop up. Pull the RAM stick out to remove it from the laptop.
Conclusie
Carlton Makini
195 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 24
Altijd: 963
