Ga door naar hoofdinhoud
HP Pavilion 15-ay041wm LCD Screen Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ay041wm LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 15-ay041wm LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-ay041wm LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-ay041wm LCD Screen Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-ay041wm LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Place the laptop on a flat surface with the lid open.
  5. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 15-ay041wm LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Gently pull away the bezel by the inner edge starting from the side until bezel is detached from screen.
    • To avoid scratching the screen, do not use any sharp objects.
  6. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 15-ay041wm LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Unsnap the two hinges attached to the clam shell by pulling towards yourself and then up.
  7. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the four 3mm screws that are holding the LCD panel in place.
  8. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Gently pull the screen from the hooks and place it on the keyboard.
    • The video cable is attached to the bottom of the LCD screen.
  9. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Peel the tape securing the video cable.
  10. HP Pavilion 15-ay041wm LCD Screen Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 15-ay041wm LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Gently disconnect the video cable to detach the LCD screen from the back panel.
Conclusie
Rahmatullo Khudoi Nazar
445 Reputatie
2 handleidingen geschreven
1Gids Commentaar
Hi. This is my first time trying to fix a computer by myself, but I'm desperate -old lady, low fixed income & this is my only computer. Please, please help! Trying to replace LCD cable, not the screen itself from HP15-ay041wm. [Screen fading from various shades of color to white & cursor freezes. Have to keep moving/tilting screen till find the “sweet spot". Then have to keep holding onto screen w/one hand while trying to type w/other. That lasts a few moments, but it eventually starts going goofy again & I have to find its new sweet spot. Hear this seems to be pretty common w/this model.] Followed your terrific directions & removed screen & disco’d the cable from screen, but now I'm stuck & panicking. How do I get the old cable past the hinge setup, get bad cable out of the main guts of the comp & get the new cable in? I've got this thing taken apart, scared to death I'm gonna ruin the whole computer and I can't afford a new one. So grateful for your help. Thx, God bless, be safe & well!
Bernadette - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 31
Altijd: 1,627
