Ga door naar hoofdinhoud
HP Pavilion 15-ay041wm Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ay041wm Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 15-ay041wm Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-ay041wm Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-ay041wm Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-ay041wm Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Keyboard Replacement, Disc Drive: stap 4, afbeelding 1 van 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Keyboard Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-ay041wm Keyboard Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-ay041wm Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: stap 6, afbeelding 1 van 3 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: stap 6, afbeelding 2 van 3 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: stap 6, afbeelding 3 van 3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
Conclusie
Kristen Gismondi
92.267 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.532 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 22
Altijd: 797
