Ga door naar hoofdinhoud
HP Pavilion 15-au123cl CD Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 2, afbeelding 2 van 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-au123cl CD Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-au123cl CD Drive Replacement: stap 5, afbeelding 3 van 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: stap 6, afbeelding 1 van 1
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 15-au123cl CD Drive Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the CD drive from the motherboard connector on the left.
Conclusie
Mohammad Gardezi
1.420 Reputatie
6 handleidingen geschreven
USF Tampa, Team S13-G3, Cagle Fall 2017 Lid van USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 31
Altijd: 644
