Ga door naar hoofdinhoud
HP Pavilion 15-ab165us Fan Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: stap 1, afbeelding 1 van 2 HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: stap 1, afbeelding 2 van 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Fan Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 15-ab165us Fan Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 15-ab165us Fan Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Fan Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-ab165us Fan Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-ab165us Fan Replacement: stap 3, afbeelding 3 van 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Fan Replacement: stap 5, afbeelding 1 van 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Fan Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 15-ab165us Fan Replacement: stap 7, afbeelding 2 van 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Fan Replacement: stap 8, afbeelding 1 van 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Fan Replacement, Fan: stap 9, afbeelding 1 van 1
    • Disconnect the fan from the motherboard.
  10. HP Pavilion 15-ab165us Fan Replacement: stap 10, afbeelding 1 van 3 HP Pavilion 15-ab165us Fan Replacement: stap 10, afbeelding 2 van 3 HP Pavilion 15-ab165us Fan Replacement: stap 10, afbeelding 3 van 3
    • Remove the the three 3mm screws with the Phillips#00 screwdriver.
  11. HP Pavilion 15-ab165us Fan Replacement: stap 11, afbeelding 1 van 2 HP Pavilion 15-ab165us Fan Replacement: stap 11, afbeelding 2 van 2
    • Remove the fan from the motherboard.
Conclusie
Chad Christy
205 Reputatie
2 handleidingen geschreven
IUPUI, Team S3-G1, Harley Fall 2019 Lid van IUPUI, Team S3-G1, Harley Fall 2019
IUPUI-HARLEY-F19S3G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 638
