Ga door naar hoofdinhoud
HP Pavilion 15-ab165us Battery and Back Cover Replacement
Wat je nodig hebt
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: stap 1, afbeelding 1 van 2 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: stap 1, afbeelding 2 van 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 3, afbeelding 3 van 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 6, afbeelding 1 van 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 7, afbeelding 2 van 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: stap 8, afbeelding 1 van 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Dillon Hubble
653 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G2, Rose Fall 2017 Lid van UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Leden
14 handleidingen geschreven
Één opmerking
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 87
Altijd: 66,492
