Ga door naar hoofdinhoud
HP Pavilion 15-AB153NR Motherboard Replacement
Wat je nodig hebt
  1. HP Pavilion 15-AB153NR Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR Motherboard Replacement, CD/DVD Drive: stap 4, afbeelding 1 van 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR Motherboard Replacement, Bottom Case Cover: stap 7, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR Motherboard Replacement: stap 8, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR Motherboard Replacement: stap 12, afbeelding 1 van 3 HP Pavilion 15-AB153NR Motherboard Replacement: stap 12, afbeelding 2 van 3 HP Pavilion 15-AB153NR Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR Motherboard Replacement: stap 14, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
  15. HP Pavilion 15-AB153NR Motherboard Replacement, Cooling Fan: stap 15, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement, Cooling Fan: stap 15, afbeelding 2 van 2
    • Disconnect fan cable from the motherboard.
  16. HP Pavilion 15-AB153NR Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Remove both 3mm screws connected to the fan using Phillips #1 screwdriver.
  17. HP Pavilion 15-AB153NR Motherboard Replacement: stap 17, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Remove the fan from the computer.
  18. HP Pavilion 15-AB153NR Motherboard Replacement, Speaker: stap 18, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement, Speaker: stap 18, afbeelding 2 van 2
    • Disconnect wiring harnesses by gently applying pressure to the plastic clip. Do not pull on the wires.
    • Disconnect the wiring harness that is routed through the speaker from the motherboard.
    • Remove the wiring harness from the groove in the speaker.
  19. HP Pavilion 15-AB153NR Motherboard Replacement: stap 19, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 19, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Disconnect the speaker wiring from the motherboard.
    • If this clip is too difficult to remove by hand, tweezers or pliers can be used to gently initiate separation.
  20. HP Pavilion 15-AB153NR Motherboard Replacement: stap 20, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Remove the speakers.
  21. HP Pavilion 15-AB153NR Motherboard Replacement, Motherboard: stap 21, afbeelding 1 van 1
    • Use the #000 screwdriver to remove the four 6mm screws attaching the motherboard to the laptop case.
  22. HP Pavilion 15-AB153NR Motherboard Replacement: stap 22, afbeelding 1 van 2 HP Pavilion 15-AB153NR Motherboard Replacement: stap 22, afbeelding 2 van 2
    • Never pull on the wires themselves to disconnect a wiring harness or ribbon.
    • Unclip the wiring ribbons from the motherboard by pulling up on the blue tabs.
    • Unplug the wiring harness to the screen by gently pulling the beige connector.
  23. HP Pavilion 15-AB153NR Motherboard Replacement: stap 23, afbeelding 1 van 1
    • Be sure to grab the motherboard by the edges. This will reduce the risk of damaging the motherboard components.
    • Remove the motherboard.
Conclusie
Christopher Hoffman
97 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G1, Stella Fall 2019 Lid van IUPUI, Team S2-G1, Stella Fall 2019
IUPUI-STELLA-F19S2G1
4 Leden
2 handleidingen geschreven
Één opmerking
A pleasure to greet you. Your contribution is very good. There is a possibility that I can make a backup copy of the BIOS of the model HP Pavilion 15-AB153NR Motherboard, in order to repair my laptop. I would be very grateful. Email: carlosjosemillan@gmail.com
Carlos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 752
