Ga door naar hoofdinhoud
HP Pavilion 15-AB153NR CD/DVD Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 15-AB153NR CD/DVD Drive Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  2. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  3. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 15-AB153NR CD/DVD Drive Replacement: stap 3, afbeelding 2 van 2
    • Slide the drive out from the right side of the device.
Conclusie
Nicole Vachon
944 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G4, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 977
