Ga door naar hoofdinhoud
HP Pavilion 14-q020nr Screen Replacement
Wat je nodig hebt
  1. HP Pavilion 14-q020nr Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • With the laptop facing you, open the clamshell. Be sure to turn the power off using a long press before beginning.
    • Remove the screw covers on both sides of the screen bezel by sliding a metal spudger into the crevice and gently peeling the cover away.
    • If the laptop turns on at any point during the repair, quickly turn it off with a long press
  2. HP Pavilion 14-q020nr Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove both 4mm screws using a Phillips Head 1 screwdriver
  3. HP Pavilion 14-q020nr Screen Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 14-q020nr Screen Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 14-q020nr Screen Replacement: stap 3, afbeelding 3 van 3
    • Snap off the screen bezel by prying with your fingers in between the bezel and the screen.
    • Continue around the screen, gently prying and lifting.
    • You will hear a series of audible clicks as the bezel disconnects from the other hardware.
  4. HP Pavilion 14-q020nr Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully loosen the bottom bezel. Eventually it will snap free from the rest of the clamshell.
    • Pull hinge up and forward to detach it from the Chromebook. The bezel and hinge cover will remain attached.
  5. HP Pavilion 14-q020nr Screen Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 14-q020nr Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 4mm screws within the metal tabs on the top and bottom of the screen using a Phillips Head 1 screwdriver.
  6. HP Pavilion 14-q020nr Screen Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 14-q020nr Screen Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 14-q020nr Screen Replacement: stap 6, afbeelding 3 van 3
    • Gently pry the metal tabs off of the screen assembly while holding the screen to unlock them.
    • Grab the screen by its unlocked tabs and tilt it down and away from the screen assembly, laying it down.
    • The new screen may scratch, to avoid this put a cloth down on the keyboard before laying down the screen.
  7. HP Pavilion 14-q020nr Screen Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 14-q020nr Screen Replacement: stap 7, afbeelding 2 van 2
    • Peel off the barcode sticker to reveal the screen connector plug.
  8. HP Pavilion 14-q020nr Screen Replacement: stap 8, afbeelding 1 van 3 HP Pavilion 14-q020nr Screen Replacement: stap 8, afbeelding 2 van 3 HP Pavilion 14-q020nr Screen Replacement: stap 8, afbeelding 3 van 3
    • Slide the connector out from its plug on the screen using your fingers to completely disconnect the screen.
    • Using your fingers, slide the connector out from its plug attached to the screen to completely disconnect the old screen panel
Conclusie
Jenell Chase
210 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team S2-G2, Bruce Fall 2017 Lid van CSU Fullerton, Team S2-G2, Bruce Fall 2017
CSUF-BRUCE-F17S2G2
3 Leden
6 handleidingen geschreven
4 opmerkingen
Where did you find a replacement screen?
Grant McPherson - Antwoord
We are only showing how to replace the screen, we did not actually purchase a new screen for this guide.
Samantha Esqueda -
i have a multi layered line going down the middle of my screen how would i go about fixing something like that?
aaron kremer - Antwoord
Sorry, we are only knowledgeable on how to replace the screen, not on the issues.
Samantha Esqueda - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 493
