Ga door naar hoofdinhoud
HP Pavilion 14-n018us Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 14-n018us Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 3 HP Pavilion 14-n018us Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 3 HP Pavilion 14-n018us Hard Drive Replacement, Hard Drive: stap 1, afbeelding 3 van 3
    • Start by flipping the computer, so that the bottom is facing up.
    • Using a Phillips #00 screwdriver, remove all of the 6.9 mm screws on the back cover.
    • Run an iFixit opening tool along the edges of the back cover to disconnect all the plastic hooks.
    • Remove the back cover.
  2. HP Pavilion 14-n018us Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 14-n018us Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Detach and remove the hard drive.
Conclusie
Briley Reichenbach
85 Reputatie
1 Handleiding geschreven
Casper College, Team 1-1, Lareau Fall 2021 Lid van Casper College, Team 1-1, Lareau Fall 2021
CASC-LAREAU-F21S1G1
3 Leden
4 handleidingen geschreven
Één opmerking
There are so many parts connected to the back cover, you can't just take out the screws and pry it off you will ruin your laptop.
I've used iFixit plenty of times and never had an issue so I assumed it was safe to follow this guide.
For example the hard drive, webcam, wifi card, and charging port are all connected to the back cover.
Joe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 315
