Ga door naar hoofdinhoud
HP Pavilion 14-cf0014dx Speaker Replacement
Wat je nodig hebt
  1. HP Pavilion 14-cf0014dx Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Speaker Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Speaker Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Speaker Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Gently lift speakers from the device.
  6. HP Pavilion 14-cf0014dx Speaker Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 14-cf0014dx Speaker Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 14-cf0014dx Speaker Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the speakers from the motherboard.
    • Gently pull and remove the speakers from the device.
Conclusie
Sam Cole
813 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 98
