Ga door naar hoofdinhoud
HP Pavilion 14-cf0014dx Fan Replacement
Wat je nodig hebt
  1. HP Pavilion 14-cf0014dx Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Fan Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Fan Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Fan Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the two screws securing the fan to the motherboard.
  6. HP Pavilion 14-cf0014dx Fan Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Fan Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the fan up and out of the device.
  7. HP Pavilion 14-cf0014dx Fan Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the fan from the motherboard and fully remove the fan from the device.
Conclusie
Sam Cole
813 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Leden
Één opmerking
Why remove the battery?
Chrillusionist - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 413
