Ga door naar hoofdinhoud
HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement, Solid State Hard Drive: stap 4, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement, Solid State Hard Drive: stap 4, afbeelding 2 van 2
    • Locate these seven 5mm circled screws on the panel that was under the keyboard.
    • Remove the screws with a Phillips Head #1 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Locate the ribbon cable near the top of the keyboard area.
    • At the cable base, lift the white tab with a fingernail and then gently pull on the blue tab of the cable to release it.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Locate the ribbon cable just above the touchpad.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Locate these eight 7mm screws on the bottom of the laptop.
    • Remove using a Philips Head #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Flip the computer back over, and using the metal spudger, remove the plastic palm rest assembly.
    • Go little by little around the edge and carefully pry off the plastic palm rest assembly.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 9, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 9, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 9, afbeelding 3 van 3
    • Locate the plastic flap holding the metal strip in place.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then gently pulling on the blue section of the cable.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 10, afbeelding 2 van 2
    • Locate these 3 screws and unscrew using a Philips Head #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 11, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 11, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: stap 11, afbeelding 3 van 3
    • Lift up the hard drive slightly and remove the black cable strip connecting the hard drive to the computer
    • Do not lift the hard drive very high, the connector cable is not very long and may get damaged if you pull too far
    • You may need to use some force and wiggling to release it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
William Busby
234 Reputatie
2 handleidingen geschreven
Cal Poly, Team 22-8, Maness Winter 2017 Lid van Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 47
Altijd: 1,218
