Ga door naar hoofdinhoud
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
Conclusie
Joe Kennedy
231 Reputatie
2 handleidingen geschreven
Cal Poly, Team 22-8, Maness Winter 2017 Lid van Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 481
