Ga door naar hoofdinhoud
HP Pavilion 14-c015dx Chromebook Fan Replacement
Wat je nodig hebt
  1. HP Pavilion 14-c015dx Chromebook Fan Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 2, afbeelding 2 van 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 3, afbeelding 3 van 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
  4. HP Pavilion 14-c015dx Chromebook Fan Replacement, Fan: stap 4, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Fan Replacement, Fan: stap 4, afbeelding 2 van 2
    • Locate these seven circled screws.
    • Remove the seven 5mm screws using the Phillips Head #1 Screwdriver.
  5. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 5, afbeelding 3 van 3
    • Locate the ribbon cable near the top of the keyboard area.
    • At the cable base, lift the white tab with a fingernail and then pull on the blue section of the cable to release it.
  6. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 6, afbeelding 3 van 3
    • Locate the ribbon cable just above the touchpad.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
  7. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 7, afbeelding 2 van 2
    • Remove the eight 7mm screws with a Philips Head #1 screwdriver.
  8. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 8, afbeelding 1 van 1
    • Remove the plastic palm rest assembly using the metal spudger.
    • Go little by little around the edge and carefully pry off the plastic palm rest assembly.
  9. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 9, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 9, afbeelding 2 van 2
    • Locate the protective yellow tape that is covering two wires in between the fan and the motherboard.
    • Remove this yellow tape.
    • Some laptops may not have this protective yellow tape. If yours does not it does not matter, just skip this step.
  10. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 10, afbeelding 2 van 2
    • Locate the single remaining screw holding the fan in place.
    • Remove the 5 mm screw using a Phillips Head #1 Screw Driver.
  11. HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 11, afbeelding 1 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 11, afbeelding 2 van 3 HP Pavilion 14-c015dx Chromebook Fan Replacement: stap 11, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Locate the wires that connect the fan to the motherboard.
    • Remove this wire connector using the tweezers.
    • You can now completely remove the fan from the laptop.
Conclusie
William Busby
234 Reputatie
2 handleidingen geschreven
Cal Poly, Team 22-8, Maness Winter 2017 Lid van Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 46
Altijd: 713
