Ga door naar hoofdinhoud
HP Pavilion 14-bk061st Battery Replacement
Wat je nodig hebt
  1. HP Pavilion 14-bk061st Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 HP Pavilion 14-bk061st Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Battery Replacement: stap 2, afbeelding 1 van 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the five 5mm Phillips #1 screws surrounding the battery.
  5. HP Pavilion 14-bk061st Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery up and away from the battery pins.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Helen Yang
163 Reputatie
1 Handleiding geschreven
2 opmerkingen
I can’t remove the backplate because I can’t find the clips. How do I get the backplate off after unscrewing the screws? (I am using an ifixit pro tech toolkit.)
DwertlePlayz - Antwoord
We were able to get the backplate unclipped by starting between the hinges and sliding the tool along until the opposite end. Then we went back to the hinges and worked our way around in the opposite direction and the plate came right off without any fuss.
Sayyed Raza -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 3,099
