Ga door naar hoofdinhoud
HP Pavilion 14-b120dx CPU Cooling Fan Replacement
Wat je nodig hebt
  1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: stap 3, afbeelding 1 van 3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: stap 3, afbeelding 2 van 3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 4, afbeelding 2 van 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: stap 5, afbeelding 1 van 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: stap 5, afbeelding 2 van 2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 6, afbeelding 3 van 3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 7, afbeelding 1 van 1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: stap 8, afbeelding 1 van 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: stap 8, afbeelding 2 van 2
    • Locate the fan in the upper left hand corner of the laptop.
    • Remove the cable connecting the fan to the motherboard.
    • Be sure not to damage the motherboard or the connecting cable. Carefully apply force to remove the cable.
  9. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 9, afbeelding 1 van 2 HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 9, afbeelding 2 van 2
    • Unscrew the 3 6.0 mm screws holding the fan with a Phillips #0 head screwdriver.
  10. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove the fan by pulling upward and to the right.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erin Lavalla
458 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 4-4, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,252
