Ga door naar hoofdinhoud
HP Pavilion 14-b120dx Audio Port/USB Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: stap 3, afbeelding 1 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: stap 3, afbeelding 2 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 4, afbeelding 2 van 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: stap 5, afbeelding 1 van 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: stap 5, afbeelding 2 van 2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 6, afbeelding 3 van 3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 7, afbeelding 1 van 1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: stap 8, afbeelding 1 van 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: stap 8, afbeelding 2 van 2
    • Carefully disconnect the cable connecting the ports to the motherboard from the right side.
  9. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 9, afbeelding 1 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 9, afbeelding 2 van 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 9, afbeelding 3 van 3
    • Remove the two 6.0 mm screws from the ports.
  10. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: stap 10, afbeelding 2 van 2
    • Push the ports to the left and lift upward to remove them safely.
Conclusie
Erin Lavalla
458 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 4-4, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 Leden
6 handleidingen geschreven
2 opmerkingen
where can I find the replacement part?
edwin abraham - Antwoord
Hello, first I just wanted to say thank you so much for writing these guides! You’re a super hero…. now then, I find myself in quite a pickle. I have an HP 15-b123cl with a screen that’s broken. I need to resolder one of the connectors. I have a picture that will show you which connector I need to fix, but I can’t post a picture in this comment section… all I need is a picture of the display connector on the top left of the motherboard. I even checked ifixit for some way of messaging you directly, but no luck :(… all I can think to do is give you my personal email address and hope that you send me something! Anyways… THANKS ERIN
Ethan
ejstepanianATgmail.com
Ethan Stepanian - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 778
