Ga door naar hoofdinhoud
HP Pavilion 14-b015dx Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion 14-b015dx Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Gregory Bridge
623 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 Lid van UMass Dartmouth, Team S1-G1, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,515
