Ga door naar hoofdinhoud
HP Pavilion 13-P110NR Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion 13-P110NR Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the two rubber feet closest to the black hinge.
  2. HP Pavilion 13-P110NR Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 13-P110NR Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. HP Pavilion 13-P110NR Keyboard Replacement: stap 3, afbeelding 1 van 1
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. HP Pavilion 13-P110NR Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the metal brace and remove it from the device.
  5. HP Pavilion 13-P110NR Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 13-P110NR Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  6. HP Pavilion 13-P110NR Keyboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 13-P110NR Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  7. HP Pavilion 13-P110NR Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  8. HP Pavilion 13-P110NR Keyboard Replacement: stap 8, afbeelding 1 van 3 HP Pavilion 13-P110NR Keyboard Replacement: stap 8, afbeelding 2 van 3 HP Pavilion 13-P110NR Keyboard Replacement: stap 8, afbeelding 3 van 3
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  9. HP Pavilion 13-P110NR Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  10. HP Pavilion 13-P110NR Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal plate to reveal the keyboard.
  11. HP Pavilion 13-P110NR Keyboard Replacement: stap 11, afbeelding 1 van 2 HP Pavilion 13-P110NR Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the keyboard from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 345
