Ga door naar hoofdinhoud
HP Pavilion 11-n010dx Fan Replacement
Wat je nodig hebt
  1. HP Pavilion 11-n010dx Fan Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 11-n010dx Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Fan Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 11-n010dx Fan Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 11-n010dx Fan Replacement: stap 2, afbeelding 3 van 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Fan Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 11-n010dx Fan Replacement: stap 3, afbeelding 2 van 2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Fan Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 11-n010dx Fan Replacement: stap 5, afbeelding 2 van 2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Fan Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 11-n010dx Fan Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Fan Replacement, Fan: stap 8, afbeelding 1 van 1
    • Use the Phillips #0 to remove the two 3mm screws holding the fan in place.
  9. HP Pavilion 11-n010dx Fan Replacement: stap 9, afbeelding 1 van 3 HP Pavilion 11-n010dx Fan Replacement: stap 9, afbeelding 2 van 3 HP Pavilion 11-n010dx Fan Replacement: stap 9, afbeelding 3 van 3
    • Use the plastic opening tool to slowly loosen the connection cable.
    • Once the connector is loose enough, grab the cable and carefully pull it free from your device.
Conclusie
Joseph Lintz
915 Reputatie
5 handleidingen geschreven
USF Tampa, Team 11-5, Blackwell Fall 2016 Lid van USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 645
