Inleiding
Make sure the device is powered off and is not attached to any electronics.
Wat je nodig hebt
Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
You must remove eleven screws.
Four 9mm screws with the PH0 screwdriver.
Seven 6mm screws with the PH0 screwdriver.
Use the spudger to pry the corners of the laptop near the display hinges.
Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
Use the plastic opening tool to lift the white tab up at the connection.
Pull the cable outwards.
Use your fingernails to slowly loosen the fan connection cable.
After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
Remove the three 3mm screws using the PH0 screwdriver.
Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
Remove the hard drive.
Unscrew the two 3mm screws with the PH0 screwdriver.
Pull the wireless card out of its port to disconnect it from the motherboard.
Push the black tab away from the hinge of the laptop.
After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
Push the white tab up toward the hinge of the laptop.
Disconnect touch pad cable by pulling up and away from the motherboard.
10 andere personen hebben deze handleiding voltooid.
