Ga door naar hoofdinhoud
HP Pavilion 11 x360 Fan Replacement
Wat je nodig hebt
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: stap 1, afbeelding 1 van 2 HP Pavilion 11 x360 Fan Replacement, Remove Screws: stap 1, afbeelding 2 van 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: stap 2, afbeelding 1 van 3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: stap 2, afbeelding 2 van 3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: stap 2, afbeelding 3 van 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: stap 3, afbeelding 1 van 2 HP Pavilion 11 x360 Fan Replacement, Detach Cable: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: stap 4, afbeelding 1 van 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: stap 5, afbeelding 1 van 2 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: stap 5, afbeelding 2 van 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Natalie
934 Reputatie
4 handleidingen geschreven
Cal Poly, Team 19-9, Maness Winter 2015 Lid van Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 2,495
