Ga door naar hoofdinhoud
HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement
Wat je nodig hebt
  1. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement, Scanner Glass: stap 1, afbeelding 1 van 1
    • Carefully wedge the flathead 3/32" screwdriver on the outer groove of the control panel faceplate.
    • Follow the perimeter of the groove with the flathead 3/32" screwdriver making sure to gently pry and lift upward until the control panel faceplate comes off.
    • Potential for device damage: Take your time prying off the control panel faceplate. If too much pressure is applied, the control panel faceplate can break.
  2. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 2, afbeelding 1 van 1
    • Once the control panel faceplate is off, look for the Lock/Unlock tab located underneath the off button.
    • To unlock and release the control panel, insert the flathead 3/32" screwdriver into the tab and carefully push down. The control panel will then separate from the printer's base by sliding it downward a little.
  3. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 3, afbeelding 1 van 1
    • Underneath the control panel will be a flat grey ribbon cable. This cable is attached at the base of the green control board with the other end of the cable located on the back side of the printer's base.
    • Carefully disconnect both ends of the flat grey ribbon cable to release the control panel in its entirety.
    • Potential for device damage: Only pull from the connector portion of the cable, as pulling on the wires may damage them.
  4. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 4, afbeelding 1 van 1
    • Lift open the scanner lid and locate a black tab located at the center of the scanner bed.
    • Using your finger push (pull on some printers) the tab towards the scanner lid. This will release the scanner lid
  5. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 5, afbeelding 1 van 2 HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 5, afbeelding 2 van 2
    • Once the scanner lid is removed, use the Philips #1(Torx on some printers) Screwdriver to remove the screw.
  6. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 6, afbeelding 1 van 2 HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 6, afbeelding 2 van 2
    • Remove all four silver screws from the corners of the scanner glass cover with a T10 Torx Screwdriver.
    • Organization is everything. Remember to have your iFixit Magnetic Work Mat next to you. It will help keep screws organized and in place.
  7. HP PSC 2410 Photosmart All-in-One Printer Scanner Glass Replacement: stap 7, afbeelding 1 van 1
    • Once you have removed the four torx screws, gently lift the scanner glass cover from the printer's base.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Hilary Olsen
251 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-31, Maness Spring 2011 Lid van Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Leden
9 handleidingen geschreven
3Gids Commentaar
2410 yazıcının kurulum sidisi exe dosyası gönderirseniz sevinirim benimki kayboldu lütfen teşekkürler. Mail. Veysiakaynak@hotmail.com
Takva Altunkaynak - Antwoord
Where can you get a replacement cord for a HP PSC 2410 Photos mart All-in-one printer
diane wood - Antwoord
Where do i get the grey ribbon for the HP2410 photodmart printer i am in Zimbabwe
Joseph Phiri - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 8,201
