Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
A damaged reflective document mat can produce poor quality images. You can replace this mat in a few simple steps.
Wat je nodig hebt
Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
Once the lid has been removed, lay it on a flat surface with the white mat facing up.
Using the flat end of a plastic spudger, pry the mat off at one of the front corners. Do this again for the other front corner.
2 opmerkingen
Would a piece of poster board work for a reflective mat?
I don’t think poster board would work because I don’t think it’s reflective enough.
Patricia -
