Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the unit so that the screen faces down.
At each side, remove the Philips screw.
Separate the back cover from the bezel with a spudger, then pull like you're gonna go mad!
Remove the two Philips screws securing the metal cover, and remove the cover.
Remove the three Philips screws of a different size than before that are securing the fan.
Trace the fan cable and remove the connector from the motherboard.
