Ga door naar hoofdinhoud
HP Omni 120 Series Fan Replacement
Wat je nodig hebt
  1. HP Omni 120 Series Fan Replacement, Remove rear cover: stap 1, afbeelding 1 van 1
    • Flip the unit so that the screen faces down.
    • At each side, remove the Philips screw.
    • Separate the back cover from the bezel with a spudger, then pull like you're gonna go mad!
  2. HP Omni 120 Series Fan Replacement, Remove fan: stap 2, afbeelding 1 van 2 HP Omni 120 Series Fan Replacement, Remove fan: stap 2, afbeelding 2 van 2
    • Remove the two Philips screws securing the metal cover, and remove the cover.
    • Remove the three Philips screws of a different size than before that are securing the fan.
    • Trace the fan cable and remove the connector from the motherboard.
Conclusie
Joseph Sctbunio
7.332 Reputatie
42 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 19
Altijd: 1,022
