HP Omni 10 Battery Replacement
  1. HP Omni 10 Battery  Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10 Battery  Replacement: step 2, image 1 of 1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10 Battery  Replacement: step 3, image 1 of 1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10 Battery  Replacement: step 4, image 1 of 2 HP Omni 10 Battery  Replacement: step 4, image 2 of 2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10 Battery  Replacement: step 5, image 1 of 2 HP Omni 10 Battery  Replacement: step 5, image 2 of 2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
3 other people completed this guide.
Alex Miller
345 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2016 Member of USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 3,953
