Wat je nodig hebt
Prepare a large workspace.
Save all work and shut down the computer.
Unplug all cables from the back of the computer, including the power cable.
Press the button on the back of the chassis labeled Internal Access. The side panel should come off.
Lift up and out to remove.
Unscrew this screw.
Slide the panel backwards against the case, and pull up.
Unplug these two cables.
Squeeze the two tabs on either side of the bay, and pull it out.
Unplug these cables and let them hang to the side.
Remove this screw, and lift up the bracket holding the graphics card in place.
Unscrew these two screws at the other end of the graphics card.
Push down on this latch behind the graphics card.
Pull firmly on the graphics card until it comes out.
Unplug each of these cables from the motherboard:
System Fan Header & 4-Pin CPU Power
LED, Power Button, & LED Strip
Front USB Ports
Hard Drive 1 & 2
24-Pin Power
Front HD Audio
Unscrew this screw at the bottom of the motherboard and remove the WiFi module. Be careful of the antenna that are wired to the module, as they are fragile.
Unscrew these 8 screws.
Carefully remove the motherboard, holding it by the fan of the CPU cooler.
Push down on these two tabs. The RAM module should come loose.
Pull it out.
Unscrew this screw.
The SSD should pop up. Pull it out of the socket.
Remove this header for the CPU fan.
Remove these 4 torx screws and pull the cooler off of the CPU.
Flip the motherboard over and pull off the backplate.
Press down on the retention arm to the right of the CPU socket. Move it to the right, and then slowly release.
Bring it up and back until the CPU bracket flip out. Carefully remove the CPU from the socket.
Unscrew these 4 screws at the back of the case.
Push down on this small bracket behind the PSU.
4 andere personen hebben deze handleiding voltooid.
