Inleiding
Use this guide to replace the internal 2.5" SATA hard drive in your HP Omen laptop with another one.
Wat je nodig hebt
Remove 10 screws from the back cover
2 large Philips #0 screws
8 smaller Philips #0 screws
Turn the laptop over and open the lid
Remove the back cover
Place an opening pick in between the back cover and main body of the laptop
Work your way around the body, snapping open the clips holding the cover in place from the inside
Turn the laptop over again and remove the back cover
The hard drive is located in the back right of the laptop
A cable runs over the left drive bar, make sure to move it out of the way before removing the drive.
Pull the back of the drive up and backwards to remove it from the laptop.
The drive bars can be removed without any tools, simply pull them to the side.
11 andere personen hebben deze handleiding voltooid.
14 opmerkingen
Thank you for this guide! I decided to give up after contacting Blizzard's live support, so I found your guide and saw how easy it is to do it by myself! The support centre did not even offer free shipping to Germany so I just followed your guide instead. Some screws had to be taken out by force (several things broke, but whatever!) and all in all, after messing around the HDD, the computer decided to boot up again! Hooray! Thank you again.
Why did you contact Blizzard about a Hewlett-Packard product? Of course they won't be able to help!
My computer had lot issues with hard drive for many time! I changed for liquid stat drive and now it works butter smoth! One problem in guide is that the omen is intact? mine was broken when i got it but i think it was a feature. also mine came with a liquid stat drive! much faster then mechanical keyboard.
Remove the back cover is a little disturbing , it seems to be detroyed in the process!...but there aren't another way. In my laptop the screw of the M2 was running free in the case making noise.........Thanks for your help!
Yeah, removing the back cover feels like you're breaking something. I found that slightly twisting it upwards (as if it were connected to the screen hinge) helps with getting it loose without it feeling too wonky.
