Inleiding
Use this guide to replace the keyboard in a HP Omen 15-5002xx. The keyboard is the main way to enter information into your computer.
Wat je nodig hebt
Flip the laptop upside down so the backside is facing up.
Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
Unscrew all 14 screw with the J00 JIS Screwdriver.
Open the case slowly from opposite sides of the laptop.
Use the J00 JIS screwdriver to remove eight screws securing the battery.
Remove the twelve big screws with the J00 JIS screwdriver.
Remove all eight small screws with the 1.5 flathead screwdriver.
Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
