Ga door naar hoofdinhoud
HP Omen 15-5002xx Fan Replacement
Wat je nodig hebt
  1. HP Omen 15-5002xx Fan Replacement, Back Cover: stap 1, afbeelding 1 van 2 HP Omen 15-5002xx Fan Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Fan Replacement, Battery: stap 2, afbeelding 1 van 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Fan Replacement: stap 3, afbeelding 1 van 2 HP Omen 15-5002xx Fan Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Fan Replacement, Fan: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Flathead 1.5 mm Screwdriver
    $5.49
    Koop
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Fan Replacement: stap 5, afbeelding 1 van 2 HP Omen 15-5002xx Fan Replacement: stap 5, afbeelding 2 van 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
Conclusie
Eduardo Arellano
621 Reputatie
5 handleidingen geschreven
Gateway, Team 1-1, Saknee Fall 2021 Lid van Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 1,652
