Ga door naar hoofdinhoud
HP Officejet Pro 8625 Display Motherboard Replacement
Wat je nodig hebt
  1. HP Officejet Pro 8625 Display Motherboard Replacement, Display Motherboard: stap 1, afbeelding 1 van 2 HP Officejet Pro 8625 Display Motherboard Replacement, Display Motherboard: stap 1, afbeelding 2 van 2
    • Disconnect the display by holding it in place while pulling down on the plastic hinge.
    • Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
  2. HP Officejet Pro 8625 Display Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Officejet Pro 8625 Display Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Officejet Pro 8625 Display Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Lift the display as high as it will allow to expose the back of the display.
    • Pinch the sides of the cover and pull away from the printer to reveal the connector.
    • Remove the connector by pulling both away from the display and towards the printer.
  3. HP Officejet Pro 8625 Display Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Officejet Pro 8625 Display Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Officejet Pro 8625 Display Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the four 6.2 mm T9 screws from the back of the display.
    • Pull the display assembly up and away from the printer.
  4. HP Officejet Pro 8625 Display Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Officejet Pro 8625 Display Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the back cover from the display assembly by pressing down on the point of connection.
    • If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
  5. HP Officejet Pro 8625 Display Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Officejet Pro 8625 Display Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 4.8 mm T6 screws from the back of the display motherboard.
  6. HP Officejet Pro 8625 Display Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Officejet Pro 8625 Display Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the connection on the front of the display motherboard.
    • Remove the display motherboard.
Conclusie
Daniel
289 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G3, White Fall 2018 Lid van Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 219
