Inleiding
The motherboard is the brain of the printer, so if anything goes wrong with it, your entire printer becomes worthless. In order to access it, you will need to remove the side panel.
To remove the motherboard, you will need to remove several connectors, so a set of small hands will be helpful. You will also need a screwdriver to remove the four 8mm T9-Torx screws securing it in place.
Be sure to ground yourself and the device when removing the motherboard and its connectors so short circuits do not occur.
Be sure to set a space aside for the screws so you don't lose them.
Wat je nodig hebt
Turn off the printer and remove the power cable.
Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
Remove all connectors by gripping the plastic housing the wires and gently pulling outward until they disconnect.
Remove the four 8mm screws by using a T9-Torx screwdriver, turning counter-clockwise until released.
Lift the ribbon connector in the center of the motherboard away after it has been disconnected to access the last screw.
Move the plastic piece away from the motherboard before removing it.
5 andere personen hebben deze handleiding voltooid.
Één opmerking
Dear Sir,
could you send me the electronic schematics for the HP 8610 motherboard and side panel . I have a problem with the switching on of the unit
thank you
Stephen Proverbs
s_proverbs@caribsurf.com
