Ga door naar hoofdinhoud
HP Officejet Pro 8620 Display Replacement
Wat je nodig hebt
  1. HP Officejet Pro 8620 Display Replacement, Display: stap 1, afbeelding 1 van 2 HP Officejet Pro 8620 Display Replacement, Display: stap 1, afbeelding 2 van 2
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: stap 2, afbeelding 1 van 3 HP Officejet Pro 8620 Display Replacement: stap 2, afbeelding 2 van 3 HP Officejet Pro 8620 Display Replacement: stap 2, afbeelding 3 van 3
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: stap 3, afbeelding 1 van 3 HP Officejet Pro 8620 Display Replacement: stap 3, afbeelding 2 van 3 HP Officejet Pro 8620 Display Replacement: stap 3, afbeelding 3 van 3
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: stap 4, afbeelding 1 van 2 HP Officejet Pro 8620 Display Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Dallas Rocha
243 Reputatie
1 Handleiding geschreven
Cal Poly, Team S19-G2, Livingston Winter 2018 Lid van Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 36
Altijd: 4,944
