Ga door naar hoofdinhoud
HP Officejet Pro 8600 Plus Motherboard Replacement
Wat je nodig hebt
  1. HP Officejet Pro 8600 Plus Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 HP Officejet Pro 8600 Plus Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Officejet Pro 8600 Plus Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Motherboard Replacement: stap 8, afbeelding 1 van 3 HP Officejet Pro 8600 Plus Motherboard Replacement: stap 8, afbeelding 2 van 3 HP Officejet Pro 8600 Plus Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Mackinnon Buck
1.182 Reputatie
3 handleidingen geschreven
Cal Poly, Team S16-G4, Livingston Spring 2018 Lid van Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Leden
10 handleidingen geschreven
2 opmerkingen
Hi,
Was having trouble with wifi connectivity. Printer says it is connected but can’t get to on the network. Shows IP address and all looks good from printer side but can’t find printer on network even with the assigned IP address. I replaced the mother board as shown above but still the same problem. Any ideas on what the problem may be? Every other device on network works fine but this HP printer. Phones, Chrome books, laptops, i-Pads… Any help would be appreciated.
Last note - There was a small circuit board attached to the mother board. I removed from the old MB and put on new MB. Could this be wireless card and if so any source for a new one. Only place I could find MB was on NewEgg.
THANKS!!
Oh, and BTW - instruction for MB removal were excellent!!
Don - Antwoord
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 72
Altijd: 4,703
