Ga door naar hoofdinhoud
HP Officejet Pro 8600 Plus Battery Replacement
Wat je nodig hebt
  1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: stap 1, afbeelding 1 van 2 HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Battery Replacement: stap 3, afbeelding 1 van 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Battery Replacement: stap 4, afbeelding 1 van 2 HP Officejet Pro 8600 Plus Battery Replacement: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Battery Replacement: stap 8, afbeelding 1 van 3 HP Officejet Pro 8600 Plus Battery Replacement: stap 8, afbeelding 2 van 3 HP Officejet Pro 8600 Plus Battery Replacement: stap 8, afbeelding 3 van 3
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
  9. HP Officejet Pro 8600 Plus Battery Replacement, Battery: stap 9, afbeelding 1 van 2 HP Officejet Pro 8600 Plus Battery Replacement, Battery: stap 9, afbeelding 2 van 2
    • Turn the motherboard over so the back is facing upward.
    • Use the plastic opening tool to pry the battery out of place.
  10. HP Officejet Pro 8600 Plus Battery Replacement: stap 10, afbeelding 1 van 1
    • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Mackinnon Buck
1.182 Reputatie
3 handleidingen geschreven
Cal Poly, Team S16-G4, Livingston Spring 2018 Lid van Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Leden
10 handleidingen geschreven
2 opmerkingen
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - Antwoord
Bonjour ,
ma batterie est ok , par contre la courroie s'effiloche.
Peut on la remplacer et si oui comment y accéder?
J'ai déplacé le tendeur pour augmenter la tension de la courroie mais ce n'est pas suffisant.
Merci
BàV phil
Philippe Herbots - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 62
Altijd: 5,287
