Ga door naar hoofdinhoud
HP Officejet Pro 6835 Speaker Replacement
Wat je nodig hebt
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: stap 1, afbeelding 1 van 1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: stap 2, afbeelding 1 van 3 HP Officejet Pro 6835 Speaker Replacement: stap 2, afbeelding 2 van 3 HP Officejet Pro 6835 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: stap 4, afbeelding 1 van 2 HP Officejet Pro 6835 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: stap 5, afbeelding 2 van 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: stap 5, afbeelding 3 van 3
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Carefully slide the speaker out of the printer.
Conclusie
David J
169 Reputatie
2 handleidingen geschreven
Cal Poly, Team S2-G4, Livingston Winter 2018 Lid van Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 275
